Shred4Ever
Why only 6 Tooth drivers ??? c/w 6.5" dia & 19/45...
Help me understand....
a 3.5" pitch, 6-tooth driver is the same diameter as a 7-tooth 3" pitch driver.
The new track is 3.5"-pitch.
Can you get a 3" track on an 7-tooth, 3.5"-pitch driver into the tunnel???
I find the skidoo marketing angle of their new color design an absolute farce. There is no way in He(double hockey sticks) that their bath tub design cools better than a properly designed finned (internally and externally) extrusion. I'd liken it to the current Polaris bath tub style extrusions.
Thermodynamically it is far more beneficial to have a lot of surface area both internally and externally to transfer the the heat out and away from the transfer medium (in this case Glycol / water). With the current Polaris and the new Skidoo G4 cooler design; it is like a bath tub which is a volume style system and as such retains far more heat than it can dissipate.
With a proper High surface area to volume ratio cooler, the manufactures could lighten the wet weight significantly by reducing the volume of transfer medium
Note: I have not seen a G4 in person or a cut away of the cooler. If the top and bottom sheets of the cooler are no more than 1/16" apart then I may have eat a little crow here. But from the drawing the cooler is far thicker than 1/16" just from the radius lines where the bottom sheet is embossed. Also guessing Skidoo opted for Lords (or similar) adhesive to sandwich the cooler sheets together, as it makes the most sense.
We noticed zero difference in performance with the one sled having an inch more clearance.
No tunnel clearance when a big chunk of ice just forms on the front. This is a pic of my 3". Wonder if the 2.6 just does the same thing.
[/URL]![]()
Sincere questions.
What sleds was this observation made on?
Was there still 1" more clearance during riding, or was the track 'slapping' at ice/snow buildup at the tunnel-closeoff on both?
Sincere questions.
