What should I do to a stock mm 700
I have a stock 2000 mountain max 700 and i was just wondering what would be some good things to change? Im planning on extending the track from 141. what are some recommendations.
Thank You
mods
depending on your budget and riding style/area your best bang for your buck mods are pipes, track 156-159, handlebar risers, skis (pretty much mandatory), gear it 18 or 19/42 and clutch it accordingly.
What do you want the sled to do?
can
track
light weight front end
2000+ rear skid geometry without transfer rods or TS skid
skis
bars and riser
19/42 gears and clutching
lexan hood
Idk list could go on and on...
X2. I also put a cat skid in mine that made a huge difference. You can pick up a used cat skid for around 300-400. Mine is a 153 skid and I have it set up to run with a 159 track. Tracks USA has the Polaris series IV tracks for a little over four bills in a 159. Used pipes are out there for 200-300, but don't forget you have to rejet to run them.
mpi transfer enhancement kit is the first thing you should do. gets rid of all the transfer rods shedding some weight and works a lot better. I put a 153 nytro track on mine it works good and it was cheap only 100 bucks because none of the nytro owners want them. you will have to go to 3" pitch drivers for this track.
