What is 2017 Mtn. Cat Helix Angle?
knifedge
1,334
542
Colorado
What is 2017 MTN. Cat Helix Angle?
--Ordered factory OEM one from Country Cat
Part # 0648-898
Stamped: 48 STRT ER
2016 Limited gives two options:
Part # 0648-904
Stamped: 66-49-.20 ER3
and
Part # 0648-898
Stamped: 48 STRT ER
--Also, are the 2017 Mnt Cat handlebars smaller diameter with smaller grips than 2016?
This is something I copied from --Arcticchat--
http://www.arcticchat.com/forum/pro...primary-boss-secondary-tuning-components.html
TEAM BOSS SECONDARY
Helix's should be available in any angle you want from the aftermarket.
I could only find these:
2 stroke engine reverse:
Straight:
0648-893 42S ER3
0648-894 43S ER3
0648-895 44S ER3
0648-871 45S ER3
0648-896 46S ER3
0648-897 47S ER3
0648-898 48S ER3
Progressive:
0648-872 65-45-.36 ER3
0648-874 67-45-.46 ER3
0648-888 65-45-.46 ER3
0648-889 67-45-.36 ER3
0648-890 63-45-.36 ER3
0648-891 63-45-.46 ER3
0648-903 64-49-.20 ER3
0648-904 66-49-.20 ER3
4 stroke (without engine reverse):
0648-901 Driven Cam (T) 58-49-.15
0648-905 Driven Cam (T) 56-48-.20
0648-867 42S
0648-868 43S
0648-884 44S
0648-869 45S
0648-870 46S
0648-885 47S
0648-886 48S
Driven Springs:
0648-856 125 200
0648-857 140 200
0648-858 140 215
0648-859 140 230
0648-860 155 220
0648-861 155 240
0648-862 160 235
0648-863 160 250
0648-864 160 270
0648-876 180 240
0648-865 180 270
0648-866 200 280 <hr style="color:#ffffff; background-color:#ffffff" size="1"> Last edited by Krom; 12-20-2015 at 09:46 AM.
<script>window.post_1473996771162_2 = function(win,msg){ win.postMessage(msg,"*"); }</script><script>window.post_1473996774329_2 = function(win,msg){ win.postMessage(msg,"*"); }</script><script>window.post_1473996777373_10 = function(win,msg){ win.postMessage(msg,"*"); }</script><script>window.post_1473996779095_11 = function(win,msg){ win.postMessage(msg,"*"); }</script>
knifedge
1,334
542
Colorado
--I was under the impression that the 2017 and early build 2016's had a 43 degree helix...but it
seems it may be 48 degree helix...in which case do I need to send it back?
evandaigneault
566
51
Portland,OR
The 2016 limited option that is a 66-49 is the low altitude 0-3000' calibration.
Regarding Mountain Cat helix angles, I was talking with my dealer about it the other day actually and according to him CAT hasn't said yes about doing a different helix angle yet for the Mountain Cats and it is Still too early to tell on the Mountain Cat Builds.
bopper
379
123
elkford,bc
The handle bar diameter is the standard 7/8" it's the inside tube diameter I believe they changed,odi ruffians fit like normal
knifedge
1,334
542
Colorado
At 9000 - 11000 ft altitude , general consesus is 43 deg angle helix works best....with a stiffer secondary spring and a stiffer primary spring...and gearing with 7 tooth or just straight up 8 tooth drivers
madmax
3,146
Salt lake city
Personally after spending over 400 miles this spring on two different 17' MC's, I think I'd leave the secondary alone for where I ride. Dropped the primary weight and changed the primary spring, was pretty happy with the results. But, it's going to depends a lot on where you ride, elevation, mods, snow conditions and mostly on personal preference.
4,078
2,799
:face-icon-small-blu bad English.
Old style secondary working great with 42-36 degrees. I mean, how 48 degree can work because angle is over 10 degrees steeper? :face-icon-small-hap
A change in helix diameter needs a different angle to get the same shift characteristics since the lever arm ratios change between the belt and the jackshaft.
mmsports
3,140
1,623
Preston, Idaho
hubsperformance.com
Clutching
I spent a lot of time testing last year on the 16le. Between the 2 new clutch I found both need tweaking. The same is going to be the case in the 17 mountain cat with one exception I will not need to regear the 17.
I found the primary weights was ones thing I didn't like. Changed them and that helped lots. The secondary worked good just felt like there was more there and I was right.
