You may want to double check you injector connections first.
Diamond is right on....
to add to his comment... look inside the connector and see if a pin is bent over or mangled inside the connector!!!
ok, so i checked the plugs, no bent pins. Motor seems to be running like a champ. Voltage regulator say 13.65 at an idle but goes down to 13.1 when bringing the rpm's up.
I'm electrically challenged but doesn't that seem backwards!!
I do have an aftermarket halogen headlight, basically a truck fog light and i'm keeping it in the on position so there is a sufficient draw on the voltage i think.
I'm wondering if the motor will still run and the light still blink if i might have the pto and mag side plugs backa$$wards??
Any ideas??
Thanx
-t
