I just finally got the sled back together and did the following upgrades/maintenance:
06 motor mounts
06 intake boots
new fuel filter
Cleaned up VES and new parts
Grade 8 hardware all around
FBF Throttle/Oiler cable
The sled runs absolutely mint! I cannot believe how smooth it idles now. It used to shake really bad at idle now it is as smooth as silk. Im am so glad I did the motor mounts and grade 8 hardware. Not to mention the sled started on the 4 pull....which I thought was pretty good. The FBF cable is a definite upgrade and should be considered on all 900 sleds. The throttle pull is also silky smooth with this cable. Anyways just wanted to throw out the heads up that if anyone is thinking about doing this (especially if you have your motor out) it is completely worth it!!! Couldnt be happier right now.... Shout out to Crix one more time for all the great help!!!
Jack
06 motor mounts
06 intake boots
new fuel filter
Jack
