I've had some overheating issues lately, Error Code 6 for the coolant temp sensor (which I cannot find...) All but the slowest speeds give me the code, scratchers down, fresh powder, it makes no difference. Eventually the wrench symbol comes on and I limp away.
I also am having a hard time figuring out which connector is from the Stator without fully pulling the engine out. (see pic)
Turning the key to on position I get nothing on the display, ignition works fine.
Also getting FUEL on the display and showing empty most of the time. Sometimes it blips up for a while then konks out. I know the gauge is notoriously wrong but it's a new issue and may be related to voltage/resistance? I burned through fuel on my last trip, thinking that the mixture went super rich...
The voltage regulator doesn't look like the OEM, looks like the previous rider replaced it... (see pic)
I'm not super small engine saavy and just picking things out of the shop manual that might be the problem. The battery is fine.
My best guess at this point is that the voltage regulator is bad...or the ECU any thoughts?
And a bonus question... see last pic... is this an overflow or should there be a hose attached
Thanks y'all !
Trevor
Thanks y'all !
Trevor
