Time to start making the Summer Mod List for my Yamaha Nytro SE.
a new track is a must for these units ! almost any track is an upgrade from the mavrick that comes stock. The 162 x16x2.5 is the best but a camo or powder claw off a cat is a cheep upgrade as well . When moving up to a 16 inch wide track you need to change drop brackets as well. i think there around 150 $ and shed 8 pounds . also some bolt grinding inside the tunnel is needed to fit the 16 inch track . also id look at a performance package from some one (clutching power commander pipe and air box ) . that way every thing works together
So the stock sled came with a "Single-ply Camoplast Maverick, in.15 in X 162 in X 2.25 in"
And you are saying the BEST would be 1 inch wider and only 1/4 inch deeper lugs??
Stay with your stock track, the 2010 version works well, not as good as the 2.4 CE but way better than previous versions. The 16 wide on the Nytro affects the handling big time.
I did the excell full exhaust and it made a huge difference. I needed a lot of weight to get the RPM's back to stock.
Do the full exhaust and clutching and you will have a fun sled.
This one??
http://www.excellmotorsports.com/fx_nytro_performance.htm
<table bordercolorlight="#C0C0C0" bordercolordark="#808080" border="1" cellpadding="2" cellspacing="0" vspace="0" width="721" frame="BOX" hspace="0" rules="NONE"><tbody><tr><td bgcolor="#000000" valign="TOP" height="439"><nobr>
[FONT=Arial,Helvetica,sans-serif]FX NYTRO HI FLO HEADER[/FONT]​
Stainless Steel 304
[/FONT]
TIG Welded
[/FONT]
Stepped Header tubes
[/FONT]
Large HI FLO Merge collector
[/FONT]
2 inch mid pipe "1 3/4 inch Stock"
[/FONT]
For use only with Stock Muffler
[/FONT]
Gain 6HP and 400 RPM's with Stock DB Levels
[/FONT]
[FONT=Arial,Helvetica,sans-serif]$499.95[/FONT]​
[/FONT]​
</nobr></td></tr></tbody></table>
Maybe that was the core issue for me this year.
So VERY LITTLE FLUFFY STUFF!!
While the "new" Maverick might be a little better than the old one, it is still a Maverick. The pattern of the lugs on the track just likes to trench. I put a 162 x 15 x 2.5 CE Extreme on my 2010 after 99 miles of the Maverick. Spendy upgrade on a 12k sled, but really, I mean really made a huge difference.
Clutching on an N/A Nytro in the back country is a huge deal. What you want is a lower RPM engagement, a smoother upshift and a good backshift. You'd be amazed at the difference that it makes. Yamaha, in my opinion, had their head up their you know what when they clutched the Nytro MTX's. Too long to engage, too hard when it does, not very good backshift. All of this leads to the sled feeling even more underpowered than it is and extra pulling on the ski loops.
Add an instrument panel vent to your list as well. You wouldn't believe the heat that comes off the top of that motor :)
And to anyone else reading this, take an avalanche class this summer. The conditions out there this year across a broad section of the Rockies were more than ripe for catatrophe. Learn it, live it, save your life for another day. :peace:
scmurs
Chris i would almost be willing to bet you that if you changed your stock track to a Camo Extreme 15x153 or 162 with 2.5" lug and you didnt feel it made a huge difference id buy the track from you for full price. As far as other mods it really depends on what your planning on down the road. And it all depends on your price range on what to get first. If boost is an option i wouldnt worry about a header. My mods if i were you would be in this order. TRACK - 700ish, Nitrous - 800, OFT Relocator, MtnVipers rollover kit, SKIs, Undertunnel exhaust (shaves alot of weight), lightweight battery
Yes that AND the muffle they offer would = the full excell system...the header I like but I personally would get a different muffler.
I am pretty well set on an under the tunnel exhaust system.
I REALLY want that space open under the seat and on top of the rear tunnel for emergency gear.
Clutching on an N/A Nytro in the back country is a huge deal. What you want is a lower RPM engagement, a smoother upshift and a good backshift. Too long to engage, too hard when it does, not very good backshift. All of this leads to the sled feeling even more underpowered than it is and extra pulling on the ski loops.
Care to share what your setup is or what you are using?
One of our members sent me this list to look over....
I am sending this to you in response to your question about upgrades.
Changing out the exhaust is a pretty good way to shave some weight and add some additional horsepower.
Here's a list of products:
Skinz SuperQ Exhaust (+ 3-4hp) = -7.5 lbs @ $249.00 = $33.20 per pound
Skinz UltraQ Exhaust (+ 3-4hp) = -7.5 lbs @ $289.00 = $38.53 per pound
Ulmer Racing Exhaust + Header (+ 8hp) = -8 lbs @ $850 = $106.00 per pound
Hartman Exhaust (+ 3-4hp) = -7.5 lbs @ $255.00 = $34.00 per pound
Schmidt Bros. Exhaust (4-6hp increase) = -7 lbs @ $699 = $100.00 per pound
CR Racing Dump Kit exhaust = -7 lbs @ $300 = $42.86 per pound
MPI Exhaust = -11 lbs @ $319 = $29.00 per pound
MBRP Exhaust = -10 lbs (+2hp) @$250 = $25.00 per pound
Aaen Mega Power Silencer = -7 lbs (+6hp) @ $425 = $60.71 per pound
Excell Motorsports Exhaust = -8 lbs @ $849 = $106.12 per pound
Ulmer also sells a header that won't save any weight but adds another 6 hp. Their exhaust + header adds a combined 14 hp. The header costs $500.
I have the SuperQ exhaust and like it. The UltraQ sounds like stock, the SuperQ is deeper and a bit louder.
Changing out the battery makes a lot of sense too. The stock unit is a beast:
Yuasa YTZ10S battery = -10 lbs @ $135 = 13.50 per pound
Yuasa YTZ7S battery = -12 lbs @ $135 = $11.25 per pound
The 7S has less crank power so it may not be best if you are often in cold conditions.
Hope this helps.
Joe
The battery is certainly good bang for your buck, but speaking from experience w lightweight batteries...it isn't worth the heartache. Maybe I got a bad couple of batteries, but it left me hanging more than once. Not fun.
I have to wonder if I would get more bang for my buck taking 25lbs off ME or off the SLED!!:face-icon-small-hap
Another list one of the readers of this thread sent me for his Nytro.
Upgrades/modifications:
1. Simmons Gen II skis
2. Simmons cutout modification
3. Hartman 2” block riser
4. Rox 3.5” Pivot riser
5. Yamaha RSI Heat grip upgrade
6. Rox handguards
7. Goldfinger left throttle
8. Timbersled Barkbuster front end
9. Fox Float Air2 front shocks
10. Sway bar delete
11. Timbersled Mt. Tamer rear suspension
12. Timbersled drop brackets
13. Ice Age rails
14. Camoplast Challenger Extreme 153x2.25” track
15. Avid anti-ratchet drivers
16. Skinz tunnel conversion
17. Skinz back bumper
18. Flap relocate – 2” raise
19. Yamaha extended front bumper
20. Snow Eliminator boards
21. Skinz Super Q Exhaust
22. Hartman custom clutch
23. Hartman ski mounted scratchers
24. Mountain Addiction bracket with (2) 2.5gal jugs
25. Yuasa YTZ10S battery
26. Yamaha skid plate
Weight savings:
1. Barkbuster front end = 9 lbs
2. Fox front shocks = 6 lbs
3. Snow Eliminator boards = 3 lbs
4. SuperQ Exhaust = 7.5 lbs
5. Rear suspension/brackets = 38 lbs
6. Skinz Tunnel conversion = 2 lbs
7. Sway bar delete = 3 lbs
8. Yuasa YTZ10S battery = 10 lbs
Total savings = 78.5 lbs
