Throttle Block help
J
Jbgough123
New member
Last ride of the season last year i busted my throttle block but luckily limped it out of the woods using the tss bypass connector i bought to carry just weeks before!
Wanting to buy a plug and play rsi billet heated block with the killswitch mounted onto it/the front and literally can't seem to find ANYWHERE with them in stock.
Are there any better options or known sources with it in stock?
The kill switch mounted forward doesn't work well in the trees.
Rsi uses the push to hold style where you have to hold it for it to kill the motor. My buddy is rocking the same setup on his m8000 and has never had a issue even in thick stuff. I've hit the stock one a few times regardless of how its mounted. My main concern is just finding a good throttle block even if it is not heated and it dosent have the kill switch forward.
Anything but the garbage that comes stock, would've prefered the rsi unit but it seems even if you had 500$ finding one is like a unicorn. Seen some on ebay but not 100% on model and the descriptions are vague. Rather not get something i have to hack or up mod to to work. Heated would've been a bonus for the iceing issue i've had a couple times as well.
Don't know if this helps the OP's situation, but I think the ZRP throttle block billet replacement parts are a brilliant idea for those with the block that pops apart all the time. Very frustrating...
All good folks! Ordered a skinz billet 2 piece block and fly billet kill switch which is a hold to kill style.
I blew mine on my pro apart enough times it would pop apart breathing on it. Used a little grip glue put it back together problem solved.
Haha I dont have patience for that. Once something oem breaks I usually always go aftermarket as a excuse.
I put a Skinz one on this summer - seems like it should work good - I guess I'll find out soon
