Took this from the website. A few peeps in my riding group have them and LOVE them. Dave did great job on these!
Introducing The Boondocker bar. The new cutting edge snowmobiles that have been released in the past few years require less effort and therefore the designs of the handlebars need to change. Designed from feedback from our network of Team riders and users, the Boondocker by CFR is the result! Do you love to ride in deep pow, lay big pow carves maneuvering through tight trees and whip off of every jump in sight?
Is your snowmobile your helicopter for accessing powder snow either skiing and or snowboarding? The CFR Boondocker with its 30 inch width, 12 degree sweep and 7 Degree Bar rise was made for you. This Bar was designed from the inside out. First of all we used 7075 double butted heat treated aluminum for a strong yet light weight base. In the center, where the stem clamps, we use a larger 1 ⅛"wall thickness, but at the end the bar tapers to ⅞".This allows the energy to dissipate over a consistent and gradual tapering within the inner core.
What's the result? Much more strength, but also much better dampening of hard hits and a better feel for what's going on underneath you on the snow. The ⅞" tapering thickness also allows the snowmobile controls to fit directly on the bar. On the outside we added a side to side and forward backward template so you can center and clamp the bar just where you want it without a tape measure. The 37 degree bar ends are great for keeping your hands from slipping off the handlebar and putting you into a tree! We wanted the Boondocker to last and look good with age so the Flat Black bars are anodized and the Monster Green and ghost white bars have a triple layered Powder coated finish.
Specs
•2' Rise
•7 Degree Up
•12 Degree back
•30" Width
•Made from 7075 Heat treated super Aluminum with flex technology.
•Strong, Light weight and tough as ****!!
•Better positioning than stock bars and way stronger! The new design dissipates bumpy conditions better than stock bars keeping you fresh and riding longer!
•Vertical and horizontal positioning graphics for perfect centering and pull back angulation.
•Designed as an all-around Boondock, hill climbing, jump and tandeming bar with 38 degree angulations on the end of the bars to keep your hands from slipping off.
•Custom graphics in three color ways. Monster Green, Ghost White or Flat black.
•All Handle bars come with a CFR Bar Pad.
