Ok, got the clutch back after the dealer went through it and got it cleaned and serviced for me, one thing I need to know.
I have the crank taper about as clean as I think I am gonna get it, I don't really wanna get too crazy as it is 15*F out and I don't want anything to freeze before I can dry it off, but my question now is concerning the inside of the crank taper where the bolt actually threads in.
I used grease on the tip of the puller to get the clutch off, and I have spent a lil time getting as much of it out as I can with Q-tips, but how important is this step? I realize perfectly clean would be ideal to make sure the bolt doesn't have any lube in there where it will allow it to back off. Any tips of ways to get the last little bit of grease out or do you think it will be ok? Should I get some hot, soapy water in a spray bottle to try to help get it cleaned up?
Thanks.
Seth... I'm not impressed!!!!
You have been riding already, and whats was it? like a 2 day turnaround to get your clutch worked on?! grrrrr mines been out for almost 2 months now.
I think your fine, so long as the bulk of the grease is gone (so the clutch bolt does not hydraulic when installed)
Got it back together, cleaned it out and got as much water out as I could with plenty of Q-tips, I'm not worried, put it back on, torqued it, ran it up to 150* (engine temp said 14* at startup, the coldest I have ever seen) spun the track a few times, torqued it again, ran it another few minutes, checked the torque again, and I'm happy for now till I get a chance to ride it a lil.
Was funny how quiet the sled was at first, not a single shimmy, squeak, rattle or anything, all the panels were frozen stiff... was kinda neatAfter 15 minutes run time it once again sounded like the 900 I know and love, HAHAHA.
