I ended up using the axys Wrist pins (102 gram) and the spi pistons. Got the pistons down to 410 grams. Coming in 27 grams lighter than stock on each hole. Ran several heat cycles and will do a leakdown test soon. Have not checked compression yet.Please keep us posted on these if you continue to be a fan or not.
Is the general consensus that the Spi hyperdrive or Tmoly pistons are a good reliable alternative to factory pistons?
Sent from my SM-G950W using Tapatalk
OEM 2015 piston better than the last polaris OEM piston?in my opinion..........
I don’t think there is a general consensus on any piston selection.
Based on the sheer numbers of oem pistons being used out there????
all my research has pointed to the oem 2015 pro rmk pistons being the best choice.......
I'm just looking at different options. Iv used RKtek on my previous sled at around 550$ Cdn shipped plus bearing and gaskets. OEM is 300$ cdn per piston plus bearings/gasket.
I have nothing against wiseco's but I personally wont buy them for a replacement.
These spi's seem to have good reviews/ best bang for your buck. I haven't read any failures with them on axys yet myself
I will follow this up as the season goes on. I am leaving the pro out of this. Different engine, different era.I was just hoping to hear some real world experience on these updated spi axys pistons.
Do you have any pictures? I thought mine looked pretty good with 3000 miles and was still pulling 120 compression. My pto side had some slight scuffing but i ingested a lot of snow last year with a torn intake screen and a leaky air box. Not the pistons fault.Just ordered a set for my 16. Mine are toast after ~2000 miles ~200 hrs
