I would look at boostit before them.Looking for feedback from those who have run one. I've been happy with my ovs. But always keeping my options open for next year in case I stay with arctic cat
And your reasoning for that statement is??? Have you run both? Pros/cons of each? I know that Neil and the Micku's both turn out great products, just wondering what your experience is...I would look at boostit before them.
good stuff guys keep it coming, there was a thread a while back but i can't find it and this is the reason why i ask. It was stated by some pretty experienced turbo guys that the best way to run is with an external wast gate off the fat part of the pipe but to drive the turbo off the stinger ut correct me if im wrong
The whole mid mount pipe thing is a bad IMO, here's why.
You need back pressure to spool the turbo , pressure is restriction , what's the restriction? the stinger is. The pressure builds at the stinger at goes back from there. You will see pressure at your stinger before the middle of the pipe.
Secondly by mounting in the middle of the pipe so much of the energy is just going right by. Mounting on the stinger the energy is harnessed better to drive the wheel.
Lastly every bend has a loss coefficient associated with it, a 90* entry on the center section of the pipe causes the energy to become turbulent , slow down , less efficient etc...
Even more so when your pipe is not pressured (bottom end) , the exhaust will venturi at the stinger and speed up, giving you better bottom end. Faster energy to drive the wheel
The exhaust going from divergent cone to center section is the slowest , slowest energy to drive your wheel.
I find it kinda strange, that despite that you obvious have not installed or ridden an instaboost kit, you still know why it does not work.
They are selling these kits.
People actually run these on their sleds, succesfully, still you can tell that it does not work.
Since you have not seen the kit first hand, I can tell you, there is a stinger. Even thou it does not looks like there is a stinger, there is.
No one said the stinger has to be in the end cone of the pipe.
2S pipes has had center and tail cone mounted stingers for a long time already. It is not that common, but it does not meen it dont work.
