K
2004 ski doo rev 151" 800ho in my tubframe I built. Runs and rides great! parting out to get a dirtbike. Has about 2500 miles on it. has rk-tek pistons and porting with a 14.1:1 head. Feel free to make offers as I want this stuff gone. if you buy multiple items I will combine shipping. Located in Bigfork MT. All prices are without shipping. call or text anytime. Kyle 406-871-0162
Tube frame with plastics - $650
Stock rev frame - $200
800ho RK-Tek Engine - $1000
Carbs - $50
Timbersled cold air intake - $30
Carb boots - $20
Y-pipe - $20
Pipe - $40
Dynoport can - $80
Motor mount - $20
secondary clutch non rer - $70
secondary clutch rer - $85
2 Used Rev belts - $25 each
MPEM with RER and no DPM - $115
RER trigger coils - $20
coil with spark plug caps - $30
Stator - $80
flywheel - $30
recoil - $30
voltage regulator - $20
Fuel pump - $20
Black fuel tank - $40
chain case with gears and chain - $50
drilled brake rotor - $25
Brake caliper, line and master cylinder
with AMP billet break lever and reservoir cap- $40
Stock rev skis - $40
spindles - $30
Rox 2" risers for 7/8 bars - $20
oil pump - $10
jack shaft - $25
jackshaft with stock drivers - $30
151 rev skid with shocks - $100
151" x16"x2" track with mising lugs - $150
front cooler - $25
rear cooler - $50
two 8" aluminum wheels for skid - $50
running board inserts for 04 rev - $45
coolant tubing - $25
chain case gears - $30
Carbs - $50
Carb boots - $20
Y-pipe - $20
Pipe - $40
Dynoport can - $80
Motor mount - $20
Stator - $80
flywheel - $30
recoil - $30
Fuel pump - $20
spindles - $30
oil pump - $10
jack shaft - $25
front cooler - $25
rear cooler - $50
