Silber turbo altitude on guages
After my 2018 silber turbo reflash my altitude reading on my factory guage is way off, says I'm at over 200 hundred thousand feet?? 2018 850.
That's normal it's because of the different map sensor.
They are working on recalculating that in the flash, just kinda low on the priority list since it really doesn't affect sleds performance at all. More of just a little nice feature to have properly active again.
New map sensor that has triple the range means your going to be at a way different voltage signal just sitting at idle then with a stock map sensor so the math for it is WAY off.
Does this also make it bounce 5000ft plus /minus when you're going down the trail. I mean just a 100ft down the trail?
