I am having trouble finding high quality Hyfax replacements for my 162" stock 2010 Nytro. It is eating the first set, but other readers say sliders like Hyperfax last MUCH longer. HELP - where can I purchase a pair?
I believe starting line performance sells the Hyperfax for the Nytro. Give them a call I was also told by my dealer to buy a anti-slab kit and mount it right where the track comes back in contact with the front of the rails. And if you are not running some sort of scratchier then i would suggest running either a ski mount or rail mount system
I think polaris if i am not mistaken has a similar profile to the yamaha rail. If you cant find specific yamaha hyperfax you can find out from your dealer which profiles are similar and run hyfaxs from a different sled just as long as they are not too loose
FYI, to run the Hyperfax, your track has to be fully clipped.
Copied from the Yamaha section for Hyperfax slides:
*NOTE: For models that have closed window tracks you must use Anti-Wear Pads.If track has all the windows open yet crossbars are not clipped, clips will need to be added.
