It is just the approach angle of the track is more graduall the height should be the sameDoesn't the '13 look like it sits lower, more squat, bit of a low rider?? I've always felt like they need more running board to snow clearance, especially compared to poo and more so Cat.
I think that a lot of weight is still a bit far forward on this chassis. Maybe just me, but I like it a bit more neutral. I also think that is part of the poo success on getting up on top of the snow is the highly centralized mass. According to these images a person would assume that the engine itself is several inches back on the poo vs doo...am I right on this?
Had to resize to match the other pics so it may be off a bit. Wasn't sure where to line them up so I went with the lower a-arm ball joint. Maybe there is a better location to line up the pro with the Doo's.
How about adding the cat? Just for fun.
Appreciate the work ! great way to see the differences in the sleds.
Yella'
50 pounds and 5 horsepower not 15. And it's way easier to add power than lose weight
Where do you get 50 lbs? 08 was 430 lbs advertised and 13 is 459 lbs. Same track. I never saw a Poo advertised at 158 hp. Where so you get your info?
What's with the gas cap location on the pro. Looks like a ball breaker
Where are you getting your info?
13 Poo 155" is advertised at 417.
13 Doo 154" is advertised at 464.
That is 47 pounds. I'll agree with you on the HP though. I think the difference is more than 5 HP.
My mistake, I thought you were comparing xp to xp over the last few years.
We are lucky to have the great machines of today. Personally I think Poo will find some weak spots that they will have to bulk up, adding a few lbs. (rear bumper for example ) Doo has had to do the same and a heavier fuel injection system. 420-450 lbs sleds will be the standard unless we want to pay more. Im ok with that, with the hp we are getting and the ride quality, we all should have smiles on our faces!
I have seen multiple dynos of the new sled on the same day same dyno and they are all within 5 hp. And I'm sure cat and poo get more of that hp to the track than the doo
No way is the Poo 5hp less than either the Cat or the e-tech, try closer to 20hp.
