removing oil injection from ext 580
E
extremsledder
New member
so my question is that i have a 1994 ext 580 and iam going to remove the oil injection because the oil pump packed it in, the thing is that there is a oil line going from the pump to the bottom of the cases the lubes the shaft that runs the water pump and oiler, and iam wondering what can be done to keep this oiled after removing the pump?
thanks
I made a plate that covered the hole. I also threaded a nipple into the plate, and attached a hose that goes up through the carburetors. I use a syringe to fill the hose with oil before every ride. I use a hose plug to plug the hose at the top to keep water from getting into the line.
I used another coolant bottle set up right beside the original one, fed the bottom end. Paint the cap black so you don't mix em up. Plugged off the lines to the jugs, and on the jugs you can solder the intakes closed or just use a chunk of tubing to connect the two cylinders. Usually good for 3 to 4 rides.
