Has anyone tried running the front of the rear skid in the lower mounting hole without doing the geo mod??? what were the results better,worse, trencher???? thanks
I dropped mine but then put it back up, too much ski lift was unmanageable in the trees
I still don't see the obvious place where you guys are drilling.
We're talking about the front skid mount.....the bolt that sits by your ankles when riding on the sled right? Moving that down what? One horizontal inch or something? (2010 tunnel BTW)
It's ok KW... you skiers are usually a bit slow, I'll draw you a diagram or somethin![]()
That bolt, dropping straight down 3/4" or so, the hole is inside the tunnel on all the sleds I've had. (2 layer of material, the hole is only on the inside layer)
In my own defense, I may just be more blind than stupid.![]()
you need to change the setup a little bit for it to work the way you want.
You can make the lower hole setup work well by setting it to run "flatter" which will give more initial lift, but then be able to stop/ control the transfer.
