It's on a Indy tank, the filler neck is about half cracked off. Should I try some super plastic epoxy or something?
Any ideas?
If you can find pvc that is the same diameter as the inside of the filler neck you can glue that inside the neck. have seen it done and it seems to work real well and is really cheap.
I've done that on old tanks that weren't warrantied, and it worked great. If you can't find the right diameter, you can have a machine shop turn it down to the right diameter, then just glue it in there.If you can find pvc that is the same diameter as the inside of the filler neck you can glue that inside the neck. have seen it done and it seems to work real well and is really cheap.
