Quick fix for cracked gas tank filler neck?
F
Flakey
It's on a Indy tank, the filler neck is about half cracked off. Should I try some super plastic epoxy or something?
Any ideas?
Any ideas?
I had the same thing happen to my arctic cat. I took it to a radiator repair shop and they used the same stuff that they use on plastic radiators for cars. It held up good and cost 20 bucks. Might be something to look into.
What TEC said........I have used mine a bunch. If you can make cereal you can weld plastic with this thing. Comes with a lot of different rod and a good DVD to get ya started. A must have if you break stuff. EW
Even welded on this small screw post
A little shaping
Good as new
Got 'em pretty cheap at Amazon right now: http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=mini+weld+model+6&x=10&y=12
broken tank
I had one on a wheeler go and I just cut it off flat a little lower. Still had enough threads left for the cap to screw onto.
There is a safety recall on certain Polaris tanks. Take you serial number to a Polaris dealer and check it out. They replaced the whole tank on my 2004 RMK Vertical Edge. If my memory serves me right if it's a safety recall any person owning that product is entitled to get it fixed.
If you can find pvc that is the same diameter as the inside of the filler neck you can glue that inside the neck. have seen it done and it seems to work real well and is really cheap.
That unit looks like the ticket EricW. I'm going to purchase one for at work "just incase we need it"....
Now that's the kind of idea I was looking for. Brilliant !
The welder looks great but for that price I could buy a few used tanks.
Thanks guys!
I've done that on old tanks that weren't warrantied, and it worked great. If you can't find the right diameter, you can have a machine shop turn it down to the right diameter, then just glue it in there.
Will gas or gas fumes have an effect on the pvc or the glue. Excess or deteriorated glue in the fuel system couldn't be good.
You might be able to weld it with a soldering iron and a zip tie as well. EW
Has not seemed to cause any problems at all. Have a friend that did it to an 02 800 mc at the start of the year and has rode the crap out of it all year and still holding strong. Think he just used the 2 stage glue for pvc.
I've got a good tank off of an '89 650 I'd let go cheap. I'll be headed over to the Shelton area in August too.
