From a few minutes of internet research; it looks like Polaris has again changed the crankshaft clutch taper size? Multiple times since the days of the carb’d sleds (30mm). (32mm) for the 700 and 900? Then (33mm) in the PRO chassis. And twice while in the AXYS Chassis. And Now with the Matryx chassis, what are they now? (I’m sure TRS or someone can verify). So I’m assuming the older Polaris-85’s need to be machined to the current taper? Is there enough meat on the clutch shaft to safely do this? Or is there a new part number for a direct bolt on?
If my internet sizes or wrong I’ll edit them. Thanks
