Mountain Cat 600 Float Needle & Seat
sdsnocop
Artic Cat Polaris Ski-Doo Klim
I am having problems finding the proper part number and supplier for the float needle and seat for a 01 Mountain Cat 600 VEV. Any help would be much appreciated.
Which number:
Ref# PartInfo
0 1670-115 TM38-B308 Complete Carburetor
1 Body, Mixing - Right
2 6505-591 Screw w/Washer
3 6506-142 Cap, Top
4 6506-034 Gasket
5 6506-137 Cap, Starter Plunger
6 6506-138 Spring, Starter Plunger
7 6506-139 Starter Plunger
8 6506-209 Gasket
9 6506-231 Funnel Assembly
10 6505-980 Screw
11 6506-232 Valve, Throttle CA 3.0
12 6506-260 Jet Needle 9DFH4-60-3
13 6505-552 Washer
14 6505-628 E-Clip
15 6506-055 Plate, Retaining - Jet Needle
16 6506-054 Screw, Machine
17 6506-043 Lever Assembly - Left
17 6506-047 Lever Assembly - Right
18 6506-053 Bushing, Clip
19 6506-040 Clip
20 6506-039 Plate
21 6506-052 Washer
22 6506-051 E-Clip
23 6506-145 Screw, Fuel Mixture
24 6506-076 Cap, Fuel Mixture Screw
25 6506-079 Spring
26 6506-078 Washer
27 6506-080 Washer
28 6506-101 Starter Jet 135
29 6505-047 Pilot Jet 40
30 6506-091 Washer
31 6505-078 Main Jet - 390
32 6506-121 Float Assembly 1.5
33 6505-875 O-Ring
34 6506-037 Screw, Float Arm
35 6506-036 Chamber, Float
35 6506-250 Chamber, Float - Assembly - Left
36 6506-038 Gasket, Float Chamber
37 6506-072 Screw, Machine
38 6506-032 Plug, Drain
39 6505-185 O-Ring, Drain Plug
40 4505-011 O-Ring
41 6506-218 Washer
42 6506-220 Screw, Air
43 6506-217 Spring
All the parts diagrams I have found on line only show the float needle as an entire assembly with the floats (No. 32) I cannot tell if the needle seat is included. I am just looking for just the float needle and seat.
Thanks, I was used to the old round slide carbs and the diagram did not make sense to me. It does now.
I have never seen one of the plastic needle and seats go bad on the flatslide carb except for one wrecked bad enough to break it.
I have one that leaks. If I do not shut off the fuel I will have 1 cylinder that will be flooded the next morning. I ordered 2 new o rings and have a parts carb coming in case I need to swap out any other parts. A new float needle valve assembly is a little spendy at $80-$90 each.
Thanks IDcatman, I replaced the o-rings and it fixed the problem.
