R
08 M1000, ported, piped, RKtech head, boondocker box. The sled runs great for a few miles then the mag side cylinder quits fueling and the egt goes cold. As long as I back it down to about 4500 rpm then it will start fueling again but you cant tach it past about 4500 or it quits fueling again.
Out of all the testing I have done this is what I have, I can get the problem to follow the mag side injector lead. If I switch the injector leads then the problem goes to the pto side hole. It does this with or without the boondocker box hooked up. I have ohmed the injector wires to the ecu plug and everything ohms out fine.
Im leaning towards a bad ECU but would like some feedback.
