I got my Goodwin kit but it had no instructions. New to this pdrive. Do I need to remove clutch. Looked on youtube but found nothing. I am going to use the 7mm spacer. 4000-7000 feet elevation. 19.8 grams. please help
You don't need to pull the clutch. Just remove the bolt that allows you to change clicker settings and replace w/ the Goodwin-provided bolt, along with the "bushing"/weight needed to hit your targeted total weight. Can be easily done in the field. Keep adding weight until you can run on clicker 3 without exceeding 8,000 RPM at WOT. Here's a post w/ a schematic: http://www.snowest.com/forum/showpost.php?p=4025743&postcount=44
