Gmrs pro handheld mic problems
Need some help from the radio experts. Last season I picked up a BTECH GMRS pro and instead of using their wired adapter I picked up a handheld mic with the correct Motorola plug for this radio. Only problem I ran into was the mic only functioned properly if it was partially plugged in. If I pushed it all the way up it wouldn’t work. My work around for last season was a spacer made from a Ranger band with electric tape around the cable and radio body. It worked and got me through the season but would like a more permanent solution.
Does anyone know if this is a radio or microphone issue?
You would have to measure the spacing on the connectors and compare to another microphone. I would assume it would be a mic. problem as there are many cheap copies out there.
Im pretty sure it is the molded body of the connector that limits the depth. Don't you have a buddy that has a mic to compare with? Try plugging his in and see if it works.
BTech apparently needed a revenue stream, so they (slightly) altered the standard Motorola plug, and sell the adapter. Usually, I look for work arounds. But this time, I bought the adapter and have had no issues with a Motorola plug pattern shoulder mike.
