This is so well said, and I agree exactly, as I have both the stock and Coil Overs in exact similar sledsHave run them both, and feel the 2020 expert package stock front KYB shocks are the best stock (non piggyback style) shocks available on a doo to date.
Installed the Fox QS3R fronts a few weeks ago and it's a far less a drastic improvement over the SP shocks that I've had in the past from upgrading to Fox. I would say the front shocks on the expert are very ridable in compared with past options, but just doesn't have the adjustability of the QS3R if that's a priority for you. Would generally say that when comparing stock settings, the stock KYB feel a little stiffer than the QS3R in factory spring preload (with no rebound/dampening adjustments).
The rear KYBs that come stock on the 20 are good, but still quite limited by the stock rear torsion spring design. Fox Evols really shine in the rear skid. I stuck with the air shocks the toms torsion spring delete kit on my 20.5 850T. Just prefer how it rides compared to stock, especially with the ability to adjust the air pressure of rear track shock for the really deep days and when I want to keep the front end down which is harder to do with the turbo in stock form unless limiter is on short. Have also found that after changing to Fox rears I can run a looser limiter strap while still keeping skis relatively low the ground on climbs.
In summary, the 2020 expert handles REALLY well stock. Shocks are super preferential and expensive, so I'd suggest trying the expert in stock form before doing anything to it. You might be surprised (I was) about how well it's setup right from the factory. It's really a pull and go rig.
Can you share your riding weight?I agree. The ski shocks on the Expert are really really good. Better than a lot of expensive aftermarket that I have run in the past. Spring rate is soft, but valving is very very good. Crank the preload to 4 after break-in and they are great. Rears are not so much, but a lot better than X Models. I am full crank on the knob on both sleds and they are soft. It has taken me a lot of years to figure it out, but proper preload on ski shocks makes a HUGE difference on Doos. You would think that a soft shock would make for better sidehilling, but it is the opposite. The G4 likes a lot of preload in the front for predictable one-ski-ing. Doos come on 1 for preload on skis, I tried a one ski run up the trail during break-in, thought the sled was broken. Now on 4 for preload, I can ride for miles on the trail, left and right corners, easy peasy on one ski. And yes, I ride in the deep.![]()
No. Pro 40s in the rear of a freeride.Are the rear shocks on the Expert the same as those on the Freeride?
The options in the accessory book would be nice to have from the factory. I'd pick the QS3 Air shocks.You're right.
I checked Doo's website and the Freeride has KYB Pro 40s in the skid and the Expert X has an HPG Plus and KYB Pro 36.
I wish Doo would let us choose from at least two shock packages when we spring order.
The main improvement for the 2020 expert sled from the KYB ski shock was the Kashima coat. The valve spec was same from previous years, but they did add the same coating technology Fox has been using for years, which helped reduce friction internally. For the 2021 season Fox aftermarket will have new internal technology that will help with both small bump comfort, as well as harsh top outs. The Fox shocks will also be lighter for next year. This technology is not being used by BRP for their Fox aftermarket shocks for next year.
Kashima coating has nothing to do with the KYB ski shock shaft... which is not kashima coated. This is all about valving stiffer as Answ3r noted.
I wish people would stop mentioning lightweight (we're talking a few pounds difference) with respect to shock upgrades. We are riding sleds that weigh 450lb+/- bone dry.
As for weight, a pound here and a pound there adds up. I'll take the lighter stuff.
This is what Doo's website says about the Kashima coating:
"Kashima coating delivers silky smooth shock piston movement for consistent cushioning through every bump - big and small."
Yet, as far as I can tell there is no Kashima coating on the shock shaft, unless it is clear colored.
Yes it is true they added 1 more shim to the 2020 valve spec, as shown in the picture below. I have shown both the 2019 Valve spec, as well as the 2020 in the picture, with an estimated increase in comp. damping. The rebound and all other shims are same diameter and thicknessExpert is valved stiffer than previous models...
