H
Well I replaced several parts in my Diamond Drive (all BDX parts) because it got chewed up last weekend, I also geared down to a 55/45 from a stock 63/57…I know it’s a big gear ratio reduction, but I want that low end grunt for the trees and the turbo is more then plenty on the hills
Vibration – I also noticed an extreme vibration from idle and at any RPM level…im not sure this vibration would be from the brass washer issue in the pic below, all bearings look to be bottomed out…so I don’t know where the vibs are coming from, the vib issue is why I tore the DD down after only one ride….
One brass washer that is coming apart…what should I do to remedy this?
Complete DD breakdown, I staged the parts from right to left as disassembled, this will show the order i had things put together….did I do something wrong? Note – this order of parts is what was suggested over the phone from BDX….the on-line micro fiche does not show enough…does anyone see anything I did wrong???
