I have a '06 M7 EFI running a boondocker turbo kit, along with all supporting mods. I'm wondering if anyone has gotten something similar to run on E85 and what the pros and cons are. Right now its set up to run 12PSI on 110 octane, but I cannot afford to go ride as much as I'd like just because of the cost of fuel. So I've done some research, and this is what I've came up with:
-E85 is usually about 100-106 octane (R+M)/2 and therefore is incredibly resistant to knocks and premature ignition, which is what I am trying to avoid running high compression, high boost, and hard use. That is the reason I have had to run 110 octane.
-E85 is highly corrosive to fuel systems that are not compatible with it. Is the fuel system in my sled going to be able to handle it?
-E85 usually needs to run 9.8:1 instead of the 14.7:1 I have it running right now. I do have the secondary Boondocker fuel rail and injectors on top of my stock fuel injection system, so I should be able to just change my fuel trim levels until it is giving me the AFR I am needing?
-E85 gets worse fuel economy because of the aforementioned increased fuel usage. In my area E85 is somewhat difficult to find, however I should be able to just fill up multiple 5 gallon tanks and be good for a weekend.
-E85 is typically harder to get started in cold weather, which is the obvious climate of a snowmobile. Will I have issues staring my sled when I first get to the mountain? Will I just be able to use a can of starting fluid to get it going in severe cold?
