Clutch squeal noise at a idol?
A
ARMYSLEDER
My clutch has a light squeal at a idol. It sounds like its from the primary. I cant figure out why it is doing it but the sled runs great and idols good just at a idol has the squeal to it. 750 miles on stock sled same belt any ideas? I was thinking maybe belt is too tight if so how you adjust it?
Deflection too tight, adjust with the deflection adjuster on the secondary to lower the belt just a little.
In your tool kit there's a brass colored long socket (like a plug tool). Stick in into the plastic adjuster and get on the nut, loosen 4 turns, then take the secondary adjust tool (in the tool kit) it has prongs on it and fits into the small holes in the plastic adjuster. Turn the tool clockwise and you'll see the sec. start spreading and the belt will go down into the sheave. Don't go too far there should be some of the belt riding above the sheave. Tighten nut back up.
alignment
it is likly to be your motor alignment, mine did the same. to align the motor loosen the four motor mounts and slide it to the mag side till it stops. at least thats for a 09? the front mount bolt by your primary will not be centered in the bracket but offset to the left side
