H
Hjalti_GTO
Got a 2013 m800 162" if you have to chose between yellow and blue prinary spring. Witch one whould you use ?
The spring radical rider suggests is a great spring. i have several of them. So are the Speedwerx H5 alloy springs. I am hooked on them now. I can't remember the colors right now but i think there is a red/white 120/340 and a blue/white 120/310. Although on paper the 120/340 should work better. On both my M8 and M8000 I have gotten a bog right off clutch engagement. For that reason alone, I now use the 120/310 H5 primary springs.
Bad advice. That spring is too much at the 340.Go with Polaris 120-340 primary spring
That is the recommended spring with MDS weights.Bad advice. That spring is too much at the 340.
Sent from my SM-G920W8 using Tapatalk
The 340 finish rate is quite stiff and it likes to break is what I have found.That is the recommended spring with MDS weights.
[emoji12]
Anywhere from 50-400miles.How many miles when they break?
[emoji12]
I am what I am. Flatlander....They last longer on trail queens.
