The 2016-2017 is a direct swap and takes the same belts. MDS does make specific weights for that clutch. I've always used the factory clutch pullers that thread into the center and push against the bottom of the hole in the crank. Remove clutch bolt, thread in puller with grease on threads and tip, tighten as far as possible with big 1/2" ratchet, rap on end with hammer, re-tighten, hammer again and it usually pops right off. I take mine off at least once a year though. If you've never taken yours off the water method with a bolt and teflon tape might be the route to go and it's low cost. Any time you replace a clutch you'll want to get an alignment bar and make sure your secondary has the right offset with the new clutch.
