Apex brake light wiring
T
thinksnow
I could use some help. I bought a used Apex and it has a VE tunnel on it. The brake light has never been hooked up. There is a cable coming out of the light with three wires. One is ground, one is marker light and one brake light. I tested the leads and the light works for both marker and brake lights.
Where are are the wires on the Apex harness to hook up the brake lights? If you happen to know what color each wire is it would help a bunch? I can't seem to find a schematic that has the wires labeled.
Attached is the wiring diagram for a Apex. Hope it helps. The plug is located in front right of seat after you take off the small 90 degree side access panel that is connected to the footwell.
Thanks a bunch. I hope the wiring is still in the sled. A propane kit is installed on it and everything is moved or changed.
It breaks away from the main harness up near the coolant overflow bottle start there and you'll find it. They wouldn't have removed it from the main harness.
