Id have to look but I should be about 3400kmCurious how many hours or miles you have.?
Yeah you'd want to clean off the excess and Run it a few times at idle and check it, thinking even a thin penetrant like some seafoam deep creep may work well to get deeper into the bearing and will remain somewhatAny lube that you spray down at the bearing will be flung out on the belt when the clutch rotates.
Yeah we use that at work, I do like the stuff, and I haven't seen the bearing so I have no idea what kind it is if it's just a bushing or if it's got needle bearings, but I'm sure anything would work, so fsr my clutch is ok otherwise and no cracks so I'd hate to have issues with the bearing there and have to replace itThe stuff you want is Wurth HHS2000 it sprays in a liquid then thickens like a grease. Every Wurth product I have ever used has been great. I am interested if your idea extends the life of the bearing,
I used to be able to spin my track over forwards but now it turns my engine over lol, If I remember right, last time I had the belt off the bearing didn't feel so smooth anymore, and believe this past weekends ride I heard a belt squeel at idle for a moment when I stopped before moving again.I dont know how you would judge the life of that bearing. I not unless it extremely crunchy. But even then, the belt could slip on it as if it were the clutch center spindle. My 153 Cross country race sled for Cains Quest has over 4000 hard miles on it and it still seems flawless
Sounds more like a clutch bind issue to me.I used to be able to spin my track over forwards but now it turns my engine over lol, If I remember right, last time I had the belt off the bearing didn't feel so smooth anymore, and believe this past weekends ride I heard a belt squeel at idle for a moment when I stopped before moving again.
edit: funny I was checking it tonight and now she spins real good again... ?![]()
I was reading on another forum of the same problem. The guy pulled his clutch for inspection and found the taper was cracked. Saved himself a pile of carnage.I used to be able to spin my track over forwards but now it turns my engine over lol, If I remember right, last time I had the belt off the bearing didn't feel so smooth anymore, and believe this past weekends ride I heard a belt squeel at idle for a moment when I stopped before moving again.
