Stainless Y pipe
Hi guys.
Our new Y pipe really makes some serious gains in which you can feel. It gains 7 hp and 4 lb/ft of torque in the mid range. Peak hp gains of 3-5.
At 8100 it gained 3 and then at 7800 and 8300 it added 5. So it has very broad powerband. We dyno tested it at Simon Cpr. Also had a customer who had one at dynotech, he picked up the same power as we did at Cpr.
We will send another one to dynotech for his independent testing as well.
But when your riding you can feel the acceleration gains and the improved low end, the motor will rev quicker. The broader powerband makes it easier to tune because you can run it at 7900 or 8300 and it pull hard at all rpms in that range.
We typically add 1.4 grams to each weight (one magnet with our weights) to the clutch with the Y pipe added, though you can run stock clutching and let it rev more too. Some customers reported that they had to add 2.8 grams per arm with the weights. I'm sure it depends on snow conditions and altitude.
They are stainless steel and polished. We spent a lot of time on tapered angles, volume, and length. The one that works the best ended up the same length as stock, yet it acts more like a longer one with the torque gains it produces, but that is because of the volume and the angle. We had another version that was longer than stock and though more volume than stock, still less than what we ended up with, and it make about 3 hp throughout the powerband. But the angle of the Y pipe coming out of the cylinder really affected things a lot, including where we change the angle the other way before the outlet. That extra volume right before the outlet brought the torque in the mid range way up.
For only $149, our Speed Shop Y pipe is a great bolt on item that works well.
It is a little lighter too. 1.7 lbs instead of the stock 2.1 lbs.
Goes well with our stainless steel canister muffler that only weighs 4.75 lbs. (17-19lbs lighter depending on whether you have the blanket version or not)
http://www.bd-xtreme.com/index.php?..._shop=1&id_employee=3&theme=&theme_font=font7
