2 years ago the drive shaft sheared off. I change it 8 months later, and now I have a bad bog/stall off start. It starts, idles fine, but when you ease into the throttle it stalls.
If you feather the throttle quickly, and get the RPMs up to about 3000, then it will take off, and and get her up to 8000 rpm no problem, let out and into the throttle, it bogs?
I have changed the boots as they were cracked. Cleaned the carbs, adjusted them, I can't figure it out.
I have been testing it at a lower elevation, 2000 feet, but it didn't do this before when I just tested it out around the yard.
