Stock 850 ETEC (for those who may be wondering)
Bore: 82mm
Stroke: 80.4mm
I understand that there are safe overbore limits with a stock cylinder.
New cylinder monoblock, 13mm overbore, and 95mm pistons... an 1140 would be nice !
Or 6mm overbore/sleeve for a 978?
Bigger bore, tuned more conservatively, no fuel control box, reflashed ECU... may give an amazing 'package'
With a super conservative stock-like tune... we should be able to expect similar HP/cc (.2hp/cc for the stock 850, which BTW is about the standard for all 2S sled twins these days)
927cc ~ 185hp
975cc ~ 195hp
1140cc ~ 228hp
Pushing harder will of course get more power... but will of course have pro's and con's to it.
TMS 927:
Anything larger than the approx 4mm overbore 927?
BTW.... what is the actual piston bore for the 927?
What pipe is used on the 927?
How highly tuned is this 927?
IE: Is it pushed hard like a race motor....
Or does it have a more conservative tune?... geared toward pump fuel at ALL altitudes and longevity/user-friendliness in mind without needing any tuning knowledge to own?
With the same level of tuning as the TMS-927 has (porting, fueling, compression, pipe) what would the stock 82mm bore in the 850 make .... what is the power diff in the two, fully tuned, engines from TMS (850cc vs. 927cc)?
