N
Hey Powder, I have been searching around and haven't had any luck with that 151' skid? Any suggestions on where I can find one?
just check the swapmeet, ebay, google, or other forums for a 151" skid for sale. or you can buy new, but thats $$$$. i'm sure you'll find one that somebody wants to get rid of, but if not just get rail extensions, and a big wheel kit then you should be fine. either way you're going to want to get a tunnel extension. good luck
So I finally got the sled into my shop, and for some reason i'm not getting any fuel to the first and third carbs. I am guessing that the lines need some help or the fuel needs to be replaced. It has been sitting for awhile. Any suggestions?
If the sled has sat for a long time with old gas in it it can plug up the fittings at the pump take the lines off at the pump that go to the carbs thats our not getting fuel. if it is not getting fuel there the pump needs to be taken apart, cleaned and rebuilt.
If it is getting fuel there plug them in and then take them off at the carbs to see it fuel is coming out. if it is not getting fuel there replace the lines. if fuel is there the needle and seat our stuck in the carb.
the carb would then have to be taken apart to fix.
you can crank the motor over with kill switch on to see if it pumps fuel in each step.
Thanks man, I am going up to work on my sled now. I will see how it works out.
