How many more people will want an xp turbo when the etec version comes out?
What are your thoughts?
Fack, Triple 7.. both of you are grasping this perfectly..kudos
The dfi sytem brp is employing is the ficht system bought from OMC.
The ultra high,( hammered) fuel pressure required to flow the low volume needed at the STOCK power level is all that can be reliably flowed. Even MINOR changes to rpm or fuel demands send these sytems off keel.
hell, the rpm ceiling alone is so low that the systems ( orbital & ficht ) have very low power limitations as volume and rpm are problems.
These were designed to just barely fuel the 2 stroke thru a very narrow window of time area for EMISSION's purposes ONLY !!
Now, the piggy back is viable to provide the added fuel volume BUT the added cylinder pressure will have a negative affect on the hammer injectors too.
e tech is not for high perf use and will teach those who try too how determined brp is too thwart them..
can you,??, yes
will there be those who will pay the cost ? yes
Gus
