8" idler wheels for iceage rails
Melfjord
Busted a idler wheel. Hit a rock, and bent it sideways. Popped the bearing out
My question is. Is there any aftermarket idler wheels that is connected together. Like Arctic cats? Needs to be 8"
Were they the plastic wheels or build aluminum? I had the same thing happened to me with the plastic idlers, put on the billet and have had no problems so far.
Sent from my Pixel 5 using Tapatalk
Cat wheels work, proclimb ones are bolted together in 3 spots so there pretty tough, i ended up with the new iceages but if i had known at the time i wouldve bought some old proclimbs and called it a day
Yes the plastic ones. ironicly the thoughest rails on the market, but prob the weakest idlers.
Do you know if the spacing and all that will fit. And i think the cat idler is 7"?. The icaage rails are made for 8" wheels
I ran m series wheels and pro climbs this year when i blew out plastic ice ages, as long as they measure 8” and the bearing i.d. is 20mm Id run it
Kmod has some he uses that rock !!
