36 INCH SPG FRONT END
GoBigParts
Polaris
I'm starting a new thread because I now have these loaded on our website for quick safe secure ordering.
This is for the Skinz Concept 36" front end kit with no shocks. They are designed to use your stock shocks which really saves on the cost. This is the closest I have been able to come to the new 850 REACT front end for your 16-20 800. I can not believe I rode a 39" front end before installing this. For more info read all the product info in the link Here is the link:
https://www.gobigparts.com/36-38-axys-spg-burandt-a-arms-only-chromoly.html
The kit comes with the A-arms and shorter tie rods as well as the hardware needed. You use your stock hardware from old Arms for bulkhead side. You know the tube with holes for studs with washer and snapring.
What I really like about this kit is Skinz made the lower A-arms high Clearance so you have more ground clearance to avoid rocks and stumps as well as they are stronger than the stock weak aluminum ones. But the key feature is the corrected geometry. So because the bulkhead is at an angle where they arms mount as your arms get shorter your spindles get pulled closer to the track making the wheelbase shorter. Skinz makes up for this by arcing the arms forward so when installed your spindles are at the same as stock location front to back but just narrowed to 36". This makes a huge difference in handling and not making your steering heavier.
As alway please contact me directly with question and pricing questions. randy@gobigparts.com
Thanks for the orders. Please post how you like the kit after install and riding it.
