all accessories are available now, but many might be backordered from guys who ordered in early, get on the list as these items will sell through as it is busy in the powersports world. Hope you had a great summer, mister!when is the new bag available?
I use the 3.7 inch and the short fits no problem. it can fit on something smaller too , if you have a longer one then you can go to the long versionHey Dave, What size riser is required for the riser bag?
Does anyone out there have a longer one...I use the 3.7 inch and the short fits no problem. it can fit on something smaller too , if you have a longer one then you can go to the long version
OK thanks, there's confusing information on the Ski Doo website stating it only fits 165mm (6.5") risers or larger. It also states it has a heater like the large riser bag. Geez!!!I use the 3.7 inch and the short fits no problem. it can fit on something smaller too , if you have a longer one then you can go to the long version
Did you swap out the throttle cable ?I use the 3.7 inch and the short fits no problem. it can fit on something smaller too , if you have a longer one then you can go to the long version
no need to, cheers daveDid you swap out the throttle cable ?
yesI bought a new xpert turbo from my dealer and just realized it doesn’t have the hand guards. Should all xperts have them?
YesI bought a new xpert turbo from my dealer and just realized it doesn’t have the hand guards. Should all xperts have them?
yes, you need the metal linq male parts the flap goes over the base plates and the metal piece go ontop of the flap and into the base plates, you need to have it set up distance wide, sorry no photo as I dont run that. cheers daveWhy does the removable flap say linq on it? Is it possible to store it on the tunnel when removed? If so, what does it look like in this position?
