All springs are at factory settings... it turns terrible and is almost impossible to sidehill. I weight 190 lbs. Any suggestions? How do you adjust front ifs spring pre loads with piggy backs in the way?
Thanks
Scott
Loosen ur ski shocks and rear track shock all the way, untill the spring rattles, then tighten 1 turn.
Tighten up the front track shock. (No idea about ur shock but make 1 full turn adjustments at a time between testing).
Make sure ur skis are centered for 36in or both shims r on the outside of the spindles for 35in stance.
Now go for a spin. If any of the shocks bottom out with ur regular riding, tighten them up 1 turn at a time and test it again in the same spot it bottomed out.
That sled should sidehill great, standing in the neutral position on anything 30° or less.
With practice u can sidehill 40° in the neutral position easily.
Sent it
