2017 800 oil line routing
11mudder
New member
25
4
3
Bought a 2017 RMK with bad top end and ended up having a cracked case. Motor all back together and getting ready to put back in, but found that the oil line routing info in the service manual is not correct if you read what it says about the high lines going to the lower case, the diagram does not show that. Can anyone tell me the proper oil line routing from the pump to the motor? Tried several searches but nothing is coming up with complete info. Can I just run the two high ports to the lower case and then the low in any order to the other ports? Just not sure how that pump works if it a rotary setup and the ports should go in a certain order or not.
11mudder
New member
25
4
3
Got it figured out, colors are correct if you if ignore the numbers shown, unless you are using a black and white copy as I was!
