H
Hey everyone, I have completely lost my mind on this problem. My 2014 proclimb Ha started flashing the temp light and shifting into reverse all on its own.
So early on my 3rd ride this season it started flashing temp. I stopped and tried to check everything out. there was a lot of snow so I was pretty certain it was not getting to hot, and I had plenty of coolant so I chocked it up to a faulty sensor. It wasn't long after that, that I noticed the sled go into reverse when we all stopped for a break. I figured I must have bumped the switch as I came to a stop. But as the day went on it just got worse and worse. At one point every time I let it drop to an idle it would go into reverse. Quite a pain. But at least a siren alarms so you know your in reverse. I took it home, took off the hood and checked every plug in the wiring harness I could find. Made sure they were all dry, and left the sled in the shop to make sure it wasn't water in somewhere. I also checked the reverse switch and it checked out OK. So my new question is this, it seems like this could be a ground issue causing both problems, where is the main ground for the ecu on these sleds, or do you all think it's a coincidence, and someone knows what's up with the reverse. The coolant sensor is a piece of cake. But reverse is driving me mad trying to figure out out. Thanks for any help
