Back to the top. Anyone confirm this?
this number shows only for 13's....heres the part numbers..pistons the same between the 12 and 13's, but the cylinders are different numbers..top number is for the 13.....
Part Number Part Description Quantity
3022449 Cylinder, SDI Mono, Offset Remove
2204322 Kit, Piston [Incl. 1,2,11] Remove
3022352 Cylinder, SDI Monoblock Remove
the offset designation is new..havent seen that on any cfi-2 or 4 cylinder before..my guess is this cylinder is going to be slightly beefier then past cylinders..but till some one gets a look at one side by side with a 12 we wont know.........this number shows only for 13's....
ModelNumber ModelName ModelYear AssemblyName PartNumber Description
S13BA8/BC8/BD8/BS8 800 SWITCHBACK PRO-R/ES/INTL/RETRO/LE All OPTIONS 2013 ENGINE, CYLINDER - S13BA8/BC8/BD8/BS8 3022449 Cylinder, SDI Mono, Offset
S13BR8GSA/GSL 800 SWITCHBACK/ES 2013 ENGINE, CYLINDER - S13BR8GSA/GSL 3022449 Cylinder, SDI Mono, Offset
S13CL8/CW8 800 SWITCHBACK ASSAULT ALL OPTIONS 2013 ENGINE, CYLINDER - S13CL8/CW8 ALL OPTIONS 3022449 Cylinder, SDI Mono, Offset
S13CM8GSA/GSL/GEA 800 RMK 155/ES/INTL 2013 ENGINE, CYLINDER - S13CM8GSA/GSL/GEA 3022449 Cylinder, SDI Mono, Offset
Even if the skirts are thicker it won't help the 11/12 guys unless they get there cases machined to accept the bigger cylinders.
I actually wasnt thinking skirts..but the entire cylinder surface, so that it hold shape better form from cold to overheated, thus allowing holding clearences tighter(thus taking the load off the piston and skirt)..but need to have a look at one before we can determine the diffs....Even if the skirts are thicker it won't help the 11/12 guys unless they get there cases machined to accept the bigger cylinders.
"No problem. I'll keep this post and re-post it in the fall when the sleds are released and you doubting Thomas' can all eat a nice serving of crow.
Have FUN!
G MAN"
SO how would you like your CROW doubters??? I do NOT post BS - never have, never will. My sources are VALID as those that know me from Dootalk can attest.
