G gxf800 Free Member Dec 22, 2015 1 0 1 Dec 22, 2015 #1 Hey guys how sensitive is it on the p tek motor to go from 1500feet to 8000 feet do I need to rejet?
S summit800 Well-known member Lifetime Membership Jul 29, 2001 969 153 43 Graham, wa. Dec 22, 2015 #2 depends on at where you ride now ? is got a base line jetting that was set up by someone , it also has the dpm in it, it should be fine
F FEZ Free Member Nov 26, 2007 584 153 43 Minnesota Dec 22, 2015 #3 No rejet required but keep an eye on the DPM solenoid. If the sled is running like a stuck pig the solenoid is probably frozen/stuck. Squirt a little WD40 in to the end and LIGHTLY poke a toothpick into the end of the solenoid. The toothpick will move about 2MM.
