ITS ALIVE
Its running really really well
I spent the last few days getting her all ready to fire up.
Clutches were serviced/built.
installed clutches and belt (belt cleaned in hot soapy water)
Added coolant and let it weep out the thermo housing with front of sled 3' in the air
I mixed up some 91 octane gas with some ethanol shield, some 2 stroke oil and added the 5 gallon mix to the tank
I powered up the fuel pump with my jumper box and let the system run for 30-40 seconds, to mix the fuel and prime the rail. I checked carefully for fuel leaks.
( Found the information about priming the pump in the stickies on top of this page, along with many many other useful posts that helped me refurbish this monster)
installed new fuel filter, air box, SLP pipe, EGT sensor, and unknown brand can, and finally the hood.
checked for oil and coolant leaks, all is well
Then I dropped the thermostat housing bleeder screw into the sled and spent about 2-3 hours looking for it with a magnet and inspection camera.
gave up on screw spent next hour finding suitable replacement
(screw is still in there somewhere! I will keep checking bulkhead for it
checked all wire routing, etc
added some more heat protection
finally time to start it.
Fires up on first or second pull every time
On first start I used coat hanger to hold oil pump full open
Dash shows full voltage, headlight is steady bright, no surging
Vibrations are non existent, sled is running really really well
Let it run to 100 degrees and shut it down
checked everything again
started again let her run to 135-138 degrees and shut her down
Running better then ever!!!
Idle is at 1600-1700 then it climbs to 2100-2200 Going to have to look into this, adjust tps, set throttle screw etc. 2200 seems a bit high
no codes, no leaks, exhaust smells/looks correct
so far so good!!
Tomorrow I will adjust idle?? and take for a test run around the neighborhood!!
Thanks for all the help guys this sucker is almost back on the trail!
Now I can rebuild the other 900
Pics:
Primary clutch taken apart cleaned and re assembled. Primary is balanced I believe, running 70g weights and 140/330 spring. One weight was sticking before all of this. The spider did not have a smooth action as the sheaves opened and closed either, everything was cleaned with brakeclean and then hit with pb blaster, cleaned some more.
Secondary was just serviced not 100 miles ago, so it was just cleaned and the 64/38 helix installed
Secondary has SLP red/black spring, derlin washers and has been spaced for belt alignment
Primary taper & crank taper cleaned with alcohol, clutch mounted and torqued to 96 ft lbs
secondary shaft lightly greased, loctite on bolt, torqued to 12 ft lbs. secondary has less then 1/4" of float on the shaft.
Belt washed and installed so you can read the letters
SLP scatter shield installed, clutches are done!
Airbox heat protected and installed
Console was installed and recoil/pull handle completed:
exhaust on!
SHE RUNS!
Now tomorrow more pictures in the snow finally
check throttle cable, set screw, tps see why the idle is climbing to 2200??
Runs perfectly aside from this! I had adjusted this TPS about 100 miles ago...will see if I can find my tester
VERY HAPPY!!!
