2003 800 XC SP parts
C
chrismorlo
New member
I blew it up last year. Now time to part it for the new one. Everything is available at this point, but the track. It had 46xx miles on it. I believe the motor is still good, but will get some pics up if needed. It appeared it lost a connecting rod bearing at the crank. Right now please pm me if you need something, as I will get the list up as soon as possible.
I know I'm forgetting things, so shoot me a pm and ask if you don't see it. Also I am open to all offers, and please let me know if I'm too high. Local pickup is in Buffalo, NY. Shipping is extra.
800 cylinders make offer
carb rack "
800 pistons "
800 case "
800 crank "
800 stator $75
Exhaust valve assembly (3xx miles) SOLD
stock Y pipe, pipe and can $150
button secondary $50
800 cdi stock $50
800 cdi stock curve with PERC and det SOLD
Team roller secondary SOLD
Track SOLD
P85 primary SOLD
front shocks (need rebuild) $200
Rear skid SOLD
Front track shock make offer
rear skid shock (needs rebuild) $75
Master Cylinder and brake caliper (everything included) $100
Trailing Arms for pair $170
Upper and Lower Radius Rods SOLD
Tie Rods SOLD
Spindles $30
Front Springs pair $30
Front Springs pair (originals) $20
Sway Bar $20
Skis Pair Stock Plastic normal wear SOLD
Drive Shaft $45
Jack Shaft $45
Handle bars w/ Throttle Block $50
Throttle Block $25
riser block (with homemade 3.5" rise) $40
Steering post $50
Steering hoop make offer
12 Gallon Black tank $40
12 gallon tank console Black $25
Air box / Oil Tank $50
Engine Straps $25
Motor Mounts $25
Fuel Pump $35
Coolant Bottle $15
Hoses available – make offer
Hood $150
yellow hood vents $15
Belly Pan $100
Skid Plate $40
Speedo $50
Tach $35
Headlight Assy $50
front bumper $20
Rear bumper $15
Tunnel Coolers make offer
Cross over hose
Front cooler
Tunnel and Bulkhead and all attached / with belly pan $250
Stock Seat (modified) seam is separating $75
Windshield bag SOLD
Mid/Tall Windshield blue $40
Mid Windshield blue and yellow SOLD
Chain case with cover $200
clutch guard $10
speedo drive + key $10
speedo drive need key $5
speedo cable $10
chain tensioner $5
Chain $30
Stock Gear Top $25
Stock Gear bottom $25
Steering Boots for both $20
Headlight/hood Harness $20
Main Wiring Harness make offer
Ignition switch $15
Drive belt – Used – 3211080 $20
Drive belt - New - Dayco HPX5020 $50
Voltage Regulator SOLD
