N
nate18
Need some help with my 17 800 axys. Has high idle 22-2300 rpm and on jack stand will only rev to about 6800. I have been working with tps and trying different settings. .700/.94 and variations of this. The one thing that is consistent no matter what tps settings I have the sled will start first pull idle for a moment or two then die. Will do this for next couple pulls also till I finally grab throttle and keep it running. Latest tps setting was at .694/.935 sled still wouldn’t keep running but once I kept it running and it warm a bit it actually idled at 1900. Thought I had maybe got it but blip throttle couple times and then back to 22/2300 rpm and would not drop. I thought I initially had air leak so checked with carb cleaner and didn’t find anything. Tested egt probe, seems to ohm out ok with heat gun????? Any other suggestions? Fuel pressure???? Do the regulators go bad???? I have primed pump a few times as I’ve had fuel rail off seems to run/sound ok. Can hear air being pushed out of system then just a constant pump hum after that. Any thought are appreciated. Thank you
