I have a 10' Dragon 800 155" and I noticed an odd issue when riding the trail back to my truck last weekend. At Wide open throttle (flappy paddle pinned to the bars) it would max out around 7700-7800 RPM. If I let off the throttle ever so slightly it would pull fairly hard to 8150-8200 RPM. I couldn't tell you what it does in the powder as it was discovered on my way back after riding all day. There are no other issues to speak of, the sled runs great with exception to this odd problem. The issue is not intermittent and it is 100% repeatable.
Any ideas would be greatly appreciated!
Thank you
- TPS set as per the FSM using one of the 9v plug in harness.
- Idle is 1650 RPM.
- Voltage regulator is of the latest design.
- PCV 5 TPS set as per the dynojet instructions from SLP.
- 150 ish Miles on top end. Indy dan monoblock and MTNTK durability kit.
- PAR 13.6:1 head.
- Reeds had no sign of issues when top end completed.
Thank you
